C4 FAB Labor Day Sale! 15% OFF!
Got mine in on Wednesday. Primered yesterday and bed linered today. Will take some pics and upload them tonight. I really appreciate the great work, packing and fast shipping. I really didn't expect them this quickly but someone had canceled an order so I lucked into them having a set ready and shipped out very fast. Thank you very much Cody.
Sent from my SM-G920V using Tapatalk
Thanks for the great comments! Glad it worked out for you to get yours a little more quickly than usual.
You said you are getting yours coated in bedliner, depending on how thick the coating is, it may cause some issues getting all of the bolts to line up. Bedliner is a very thick coating that will affect the fitment of the slider. The extra thickness of material doesnt allow the slider to fit up to the frame as tight as possible. You may have to clean off some of the bedliner from around the perimeter of the mounting holes to allow some room to adjust the slider. Hopefully it wont give you too many issues!
If I were to have them mask off the area that mounts against the frame so that is paint only would that be ok? My plan was to do this as I know with other items in the past liner can throw measurements off.
Check out the post above regarding coating the sliders with bedliner. It may cause some issues with fitment depending on how thick the coating is.
That would be perfect. The slider should fit as usual that way. Then the only thing you might have to worry about would be the mounting holes having a smaller diameter than usual because of the extra coating around them.
I only ended up having an issue with 2 holes not lining up when I put the drivers side slider on. And it is caused but the weld on the frame at the trailing edge. I will have to do a little grinding on the frame weld so the slider slides up correctly. The bed liner came out looking great for a home done job. 2 heavy coats of hurculiner.
Sorry for the crappy pics but a broken lens on my phone doesn't take the clearest pics.
I chose the bed liner for the steps just so it would have extra grip from the texture.
Cool, glad you didnt have any major fitment issues! So far we have had a couple customers that needed to sand their lower frame weld just a bit for proper fitment. Some welds must hang down farther than others. Pretty easy fix though.
Yep I didn't have a grinder at home so I went ahead and mounted it and will pop it back off sometime at work and grind it down.
Is this a 2018 thing too???
I certainly hope so, I'm just about ready to pull the trigger on a LoPro.
Thanks for digging this up...!
I'm waiting to see if several companies announce a sale... Here's hoping!
I tried that coupon..No go:noidea: I hope they bring it back too. Right now they only have a special on their GB Ladder.
Sorry guys, no Labor Day sale planned for this year. We are trying to get caught up on orders and cut down on lead times in order to prepare for the release of our new t4r rear bumper.
Labor Day sale would just put us behind.
On a positive note, our lead times are currently down to 3-4 weeks!
Understood, appreciate the response.
On a side note, I'm looking to order a LoPro and do a custom hoop on it. What OD/ID tubing do you guys use...?
Ambrose67
