C4 Fabrication Rock Sliders Group Buy
[MENTION=131444]C4 Fabrication[/MENTION]
If I remember correctly, there is no option for welded on step plates any more, right? So the option is either with step plates, or without, correct?
Steve
That is correct. If you order step plates, they will always be remove able. Retail price on sliders without step plates is 550.00.
'11 Trail?
I'm as green as they come so please bear with me if these are dumb questions. I see someone signed up with a '12 model SR5. I've got an '11 Trail, would I also be able to jump in on this? I see on your site it says '14+ So wasn't sure if this buy opened up the earlier 5th gens.
Also, are there pictures of the removable step? That doesn't mean the whole slider because it's bolt on right? I'm a little confused on this one, none of the pictures make sense to me when I'm looking for that, but I'm probably just looking wrong too.
Thanks in advance!
Thanks in advance!
Physically the sliders should fit your '11 trail. The only issue we have not resolved for sure is if all of the mounting holes on the frame rail are the same on the pre '14 5th gens. We will be getting one in the shop before the GB closes to check fitment and see if the mounting will be the same.
Sorry the pics are a bit confusing. The pictures that Fargo4x4 posted show our original version of the sliders with the welded on step plates. All of the step plates are now made remove able to make it easier to paint or powder coat. Here are a couple pics of what the sliders look like now with the remove able step plates.
We now use torx, pan head 10-24 self threading screws to hold the step plates on
Thanks! That clarifies both very well! I'll keep an eye on the thread if you don't mind updating it once you do get the pre '14 model to test it on. Also, is the step plate option removable only or can it be welded on as an option?
Thanks again, if everything works out, I'm likely in too but not quite yet. Excited though!
We could weld the step plates on if you absolutely needed them that way, but to be honest you will always have rust issues coming from under the steps where they connect to the outer tube. Its just impossible to get paint or powder coat to completely cover that area. That is why we switched to the remove able style.
Would you be able to call your powder coating person to see how much they would charge for 2 of the 3 steps you normally do? I would be interested in the sand blasting and the zinc rich primer bath. That would give me a great foundation to apply paint and hopefully combat some rust issues down the road. Thank you!
I could find out what the price difference may be.
Abso-freaking-lutely
I am in. Got the wife's approval! 2014 SR5, bare metal, with skid plates.
Your product looks amazing, can't wait to see how it looks on mine.
Thanks for the great comments! We've got you added to the list, thanks!
1) kSteven813 - 2016 trail w/ kdss - Powder coat w/ remove able steps
2) alico268 - KDSS - bare metal w/step plate
3) BRODIN - 2016 trail - Powder coat w/ removable steps
4) Ohio_Steve - 2016 Trail w/KDSS - bare metal w/step plate
5) popey - 2016 TRD Pro - Powder Coat with removable steps
6) Alaska_4Runner - 2012 SR5 - Bare Metal W/Removable step plate
7) Jaydub514 - 2016 Trail w/KDSS - powdercoated w/step plate
8) LandoSystem - 2016 TEP w/ KDSS, bare metal, removable steps with dimples instead of the logo
9) dell - 2016 4Runner TEP w/KDSS, powder coated, step plates with dimples instead of the logo
10) ds4runner - '16 sr5p bare metal with steps no logo all dimples
11)DarthRaider - 2016 TEP - w/o KDSS: SR5, w/Step Pads, Satin Black Powder Coat.
12) FlyingScout - 2014 SR5 Bare metal with step plates.
halflife78 - 2016 TRD Pro - Powder Coat with removable steps (I assume TRD Pro logos correct?)
Yes we can use the PRO logo steps on yours
13) halflife78 - 2016 TRD Pro - Powder Coat with removable steps- TRD Pro logo steps
5) popey - 2016 TRD Pro - Powder Coat with removable steps, no logo
On mine, I would like no logo steps. Thanks!
Added that for you
5) popey - 2016 TRD Pro - Powder Coat with removable steps - no logo
Ambrose67
