C4 Low Pro install questions
hinmo24t
I figured I wouldnt clog the other thread with a lot of back and forth so ill ask a few questions here.
Looking for someone who has installed the c4 low pro winch bumper on a 2003-2005 style 4rs.
Do you have to pull the battery and worry about airbag harnesses or sensors? You remove the front piece of the bumper or crash bar for it I believe which is why I'm wondering... do you have to move any substantial lines on the truck to fit the assembly? Id like to find a superwinch setup synthetic w aluminum non roller 8000-9500 lb non integrated. Would prefer whichever fits easiest as my mechanic skills are in the B range, I do have some friends if need be though.
You SHOULD unplug the negative terminal on the battery just to be safe. As far as anything substantial you need to remove is just the front bumper cover and then the reinforcement bar. Install low pro bumper and trim front bumper cover
2001ATL
