UnlimitedT4R
A couple questions.
1) I'm away from the truck so I used Joelzy's photo. The passenger side "headlight" piece was undamaged. I'd like to try to not remove good material if possible, and removing that piece will require disassembling the A/C system because a pipe goes through it. So can't I just remove the spot welds circled in the photo below? That will take off the horizontal supports and leave the headlight piece on the truck which I know is good because it "lines up" (as well as a Certifit hood "lines up") with the new hood. I looked before and it looks pretty straightforward. The advantage of this is that it will be easy to line things up so they are in the right place.
2) Regarding the other end, you are suggesting that I overlap the sheets and weld that up. But on Arthur Tussik's channel I have seen him overlap the sheets and then run a grinder through both so that the cut is perfectly lined up. Then he welds that up so there is no seam. Can I do this, or is it not structurally strong? If I overlap then weld, I will have a raised line. Also, would I have to weld both lines of the overlap, one on each side?
As mentioned, I probably should have cut out the firewall too with the donor piece so I could take it all the way back to that. But on the other hand I think messing with the firewall would create some extra complications. The wheel bay isn't highly visible so I could get away with cutting a line and re-welding.
The metal is undamaged back at the firewall. Everything just folded up to the firewall. I test fit a driver's fender and it lines up well with the hood and front of the vehicle. The hood pillar is fine. The frame seems perfect except a bent lower control arm rear bracket which I'll deal with after I get the front end put back on and it's drivable.
I’m using my phone right now so I can’t tell from the photo what’s going on with the headlight “bucket” I’ll put eyes on mine in I few to get a better idea. As far as the drivers side upper rail/apron overlapping with plug welds would be the most structurally sound option. On areas you can’t overlap butt seams up and weld. Like you said, not much of that will be visible so focus on alignment and structural rigidity and you will be good to go. Give me some time to look over my runner to get a better idea of the details and I will get back with you.
