Car tires in use should be noted that
furong7788
On the use of tires will pay attention to what? I drove quite a long time, and now own a little experience to share with you, see I said right, hope to add.
Before and after one visual tire pressure at any time, to see the car up and down to the tires more than one, to see whether the normal, to see whether the obstacles.
Regularly check the tire pressure (including spare), summer front 2.0 rear wheel 2.2 as well, the winter front 2.2 rear wheel 2.5 as well, such as full load can be adjusted and other reasons, must be inspected before the high-speed. (In the pressure this is purely my personal point of view, we can refer to the manual), tire lack of air will accelerate tire aging, extremely dangerous at high speed, easy to puncture. Air feet will be fuel-efficient, but the loss of comfort and grip.
Keep the tires clean, timely cleansed, do not be careful to stick to the oil, the snow should be immediately after the car wash.
Regularly check the tire tread and sidewalls from the out set the entrainment of gravel in the tire grooves, use a screwdriver, etc., the nails must not be starting as soon as possible to find and repair the tire wall with the palm of your hand gently touch to see if the bulge phenomenon, if any, must find professional local inspection.
Driving, try not to pressure on the road covers, and other items left lying in the road all do not pressure, to form good habits.
Nearly six, away from the curb child Do not rely on street parking, from near the sidewalls very easily pushed the tires hurt (do not believe that they can try, less than 500 yuan tire a squeeze a bag, do not say more than 500 yuan) really insisted on the curb child is not available, as tires are to a large angle, the smaller and more easily cut into the tire.
Seven, when driving at night, as long as it is reflective of the things not to pressure, there may be shards of glass and metal debris.
8, away from the construction site, especially the site of the renovation, small shards of glass and metal debris nail is very large, non-go, it would slow down. Fast speed of the front wheel rolled up things so that the rear wheel very easily caught. There are some road construction, covered with a kind of a big iron, to go in the middle of the iron, do not pressure the edge.
Finally, alloy wheels, kept clean, clean the glue cement, asphalt, oil, etc., the weather is good, clean home Bili Zhu spray again, two days later with a clean rag to wipe then spray again, so the future will be very good care. Want a half a day before so many good again.
I think this was written in Chinese and the computer tried to translate. Chinese would be easier to read.
WTF was that?
Confusion, this post make for me one, maybe two. I think words use of good not making for read of tires.
You've got to be kidding me. I've been further even more decided to use even go need to do look more as anyone can. Can you really be far even as decided half as much to use go wish for that? My guess is that when one really been far even as decided once to use even go want, it is then that he has really been far even as decided to use even go want to do look more like. It's just common sense.
youngrk
