Cargo Basket Recommendation - 4th gen SR5 with sunroof
wolfgang.rumpf
I want to add a cargo basket to the existing roof rack on my 4th gen SR5 - I have a sunroof, and I think it would be nice to not cover it with said basket, but I'm open to all suggestions. Any recommendations?
I've been using a Kuat Vagabond with good luck. It is big enough that it holds plenty of gear, but short enough that it doesn't cover the sunroof- it stops just at the back edge of the glass.
I would recommend getting an exrta set of cross bars since the factory bars are a little flexy. The roof rack bounces while driving on cement highways when I have the roof basket and a hi lift jack, and I've been wanting to add an extra set of cross bars to stiffen everything up. Also, go around and tighten up all of the bolts (especially the ones under the cross rails and bars) so you have a quiet rack.
I have the Yakima Megawarrior and it has been very good. I use it quite a bit and for the price it is worth every penny. You can also look at the Rola rack as it is inexpensive and a little lower heightwise thank the Yakima.
Rola with Lo-Pro brackets from 4XInnovations is probably your most cost-effective bet. I had one and loved it until I upgraded to a full rack.
Philthyphilthy
