Carrying a Chainsaw
DavidR1
I like to take a chainsaw whenever I go to the trails. There seems to be blow downs all the time and its always nice to clear the roads.
I don't have a full length roof rack and don't plan on adding one. Does anybody have a suggestion on a way to safely carry a saw on the outside of their vehicle, preferably on the factory roof rack. Any suggestions?
You could fabricate a plate that attaches to each cross rail and has brackets for your saw to mount to. That's probably the cheapest "secure" way to do it.
I bought one of these 20v versions for about $100 around black friday. With two 9ah 60v batteries that I already have for my cordless tools - it's amazing how much the little saw will cut. I'm probably going to sell my little stihl ms170 that was my camp saw. If you're cutting all day - the gas saw is by far the better choice. If you need to clear a log or two - the cordless saws are the answer. No mess (It does use chain oil). No noise. No smell. No hassle with starting. And while they're kinda $ if you don't already have batteries, they're cheaper than most gas saws by the time you add a gas can, a case, roof rack to store it outside the car. And it weighs next to nothing.
Lots and lots of this
Sent from my SM-G930V using Tapatalk
It's not what you asked,
but I carry mine inside the 4runner for a lot of trips. I use the husqvarna powerbox,
and it fits extra fuel, bar oil, ear protection, gloves, files, scrench, and a small axe.
Get a Thule or similar car top carrier. When I know I'm in the woods a lot, I just leave it on for a few months. Put saws, come-a-long, shovels, fuel, etc and it all stays high and dry, locks up tight so I don't always have to load that stuff, it's always ready to go. Sure it doesn't look as cool as having a hi-lift strapped to your roof but very functional IMO.
Google snowmobile chainsaw carrier. Lots of good options.
Just make sure it's not an assault chainsaw, they say those are very dangerous
Inside
Why would you want it on the outside? It will snag on things, get stolen, and if cold, will never start.
For years I have rolled w/ an 18" Stihl that easily disassembles & fits in a small, smell tight Rubbermaid box. Just put xtra fuel & oil in Ziploc's...
transporting a chain saw
Occasionally I transport my chain saw up to a friend's cabin for tree trimming and clearing work. I have a 24" Stihl that I bought the carry box for. I keep the saw inside the truck. I carry a one gallon gas jug, a pre-mix jug for mixing fuel and the various oils on top in a crate that I tie down. I don't want gas cans or oils inside the vehicle.
I have a Baja Rack flat utility rack that I tie things down to. The main problem with the Toyota roof rack is that anything you tie down on top sits directly on the roof paint. As things move around on rough roads the top gets scratched. There are ways to work around that, like putting stuff on boards that span between roof rack rails or putting pads down below boxes and hard stuff. Cardboard makes a decent pad, but it's not going to last if it rains.
Generally, you should be running your chain saw dry between uses because old gas in the carburetor is not good for these two stroke engines. If you do, the saw will not be full of fuel when it's inside your car. I dump my unused saw fuel back into a pre-mixed fuel can and then run it for a minute to empty the carburetor.
I use a Stihl 201TC with a 16” bar. What I carry it in is a Stanley tool box that has a o-ring that keeps in the smells for when I store it in the cab, and keeps the weather out for when it’s on the roof. I can fit all the necessary tools, safety gear, gas, and oil inside too. Also the removable tray that sits along the inside top I cut down in length to clear the hand brake.
Only problem with running things dry is that if stored over time, the orings can dry out and deteriorate, then when you add fuel and run again, they can leak.
I second the Dewalt 20V chainsaw, the thing is amazing! I bought an extended Oregon bar/chain combo for it but haven't even installed it yet because the stock setup has worked for the little jobs I have used it for.
Pretty much every lawn guy and 2 cycle repair place I know of all say run it dry before storing. I've been doing that for years with all my stuff and never had an issue, including my ancient homelite super 2 and that thing might be older than I am.
Sent from my XT1650 using Tapatalk
Talyn
