CBI Deal Of The Day
CBI OffRoad Fab
Todays deal is a rear bumper for a 1st gen Tacoma. The Outback 1.0
The benefit of the Outback 1.0 is that you do not need to cut the quarter panel of your truck to mount it up and it is a light weight option for full bumper and quarter panel protection. Finally a rear bumper with uncompromised strength and durability to withstand your harshest abuse, and recovery points to get you out of those tight situations. The Outback 1.0 comes standard with the receiver hitch built in behind the license plate. This bumper can also be purchased without a receiver so that the factory receiver hitch can be utilized to maintain tow ratings.
Todays deal is The Xray Vision driving light by TJM
Plus get a FREE wiring harness when you buy 2 lights
The Xray Vision driving light range is based around precision computer-aided manufacturing to maximize build quality, light output and beam pattern accuracy. So whether you want to see or be seen, TJM has engineered the very best premium quality lighting equipment you need for your 4WD adventures!
Todays deal is a set of flat CBI Bolt on sliders
Sliders come powder coated black
Reg. $584.99 Now only $449.99
These CBI Off-road rock sliders come powder coated black and are built for the true OFF-ROAD enthusiast! Each slider is construction by one of our skilled fabricators out of Hot Rolled Electric Weld tubing (H.R.E.W. 1.75″ x .120 wall), with ¼” thick mounting brackets. The included grade 8 mounting hardware make these sliders rock solid and durable to handle whatever punishment you can dish out. CBI offer sliders with the most evenly spaced stand offs to the frame that give them the best performance and strength compared to other manufacturers. (No long unsupported length near the back end) The rock sliders can also be used as a lifting point for a hi-lift jack and will support the full weight of the vehicle. Each slider can be ordered in a variety of configurations to meet your needs or we can custom build the perfect set for your application. The bolt on application makes installation easy and doable for all.
Call to order Toll Free: 866-522-0697
Whether you are preparing for an emergency or camping cross-country, InstaFire Adventure Gallon buckets not only provide you with a convenient and easy firestarter, but an easy storage solution as well. With 24 individual InstaFire pouches, this 2 Gallon bucket is easy to carry, easy to store, and extremely durable.
Todays deal is The TRED Total Recovery & Extraction Device
TRED is the ultimate all-in-one off road recovery device, specially designed to get your four-wheel drive, ATV and equipment out of trouble when traction is lost in sand, mud, sludge, slime or snow.
Engineered and manufactured in Australia from only the highest quality materials, TREDs are designed to handle intense levels of torque, flex, weight and impact. Intense reviews of every fine detail in the design process make TRED the best choice for your recovery. With a designated shovel feature, extreme hex grip nodules, aggressive ramp entry teeth and ultimate wear resistant properties, TRED will allow you to explore with confidence, without letting traction disrupt your journey.
Plus get free Shipping
Todays deal is The TJM OX Heavy Duty Recovery Kit
Stuck on a slope or stuck in the mud, TJM can provide a lot more than sympathy. 4x4 Driving can be full of fun and adventure, but it's certainly not much fun when your adventure comes to an abrupt halt. At TJM we've "been there, done that" a thousand times, so we've come up with all the recovery gear you'll need
Tested to withstand the harsh conditions of the Rocky Mountains and Mojave Desert, this heavy duty kit exceeds even our high standards.
Product Features:
• 11000kg snatch strap 75mm x 9m
• 6000kg winch extension strap 60mm x 20m
• 10000kg tree trunk protector 75mm x 5m
• 8000kg snatch block
• 19mm bow shackles x2
• 16mm bow shackles x2
• Heavy duty recovery gloves
• Recovery blanket
•*Handy Carry Bag
Jhunt
