CBI Offroad Aluminium Front Bumper with TRD PRO Skid Plate
SnoRnR
Does the CBI front bumper fit with the TRD PRO skid plate? I have yet to find a picture online with this configuration.
Im guessing it looks bad with the colour difference and the fitment.
Yes, it fits with no problem....Mine has been painted black to match.
Sweet rig. Did you get steel or Aluminium? I am guessing by the 700lbs spring rate in your signature that you went steel. That looks good will look to paint the skid too. What paint did you use? Did you remove the TRD letters and then replace or mask off?
Also,
did you install the Baja designs fogs? Which kit did you use? Do you have to purchase the 4runner replacement kit with harness and mounts? I'm hoping you can just get the Squadron SAE lights and a separate harness connector save some cash.
Also,
Thanks man....Yeah, I got the aluminum front CBI bumper.
I believe I used some flat black Rustoleum, and I put the red TRD letters on after the fact. I will just tape off the letters in the future when in needs to be touched up.
And as far as the BD fogs, I did install the lighting, and for simplicity, I did use their 4unner kit with the harness/mounts ect., but yeah you could probably save some cash doing it your way.
Good luck with the build brother!
Tx470
