Center console AC115V 100W; what are you using?
levi10moore
I recently purchased this (Wall Charger, Amoner 2Pack 15W 3-Port USB Charger Cube Portable Travel Wall Charge... https://www.amazon.com/dp/B07K46Y37L/ref=cm_sw_r_sms_c_api_i_VKU5CbTX1Y677) plug that has 3 USB port attachments thinking how nifty that would be and clean it’d keep my chord management. However it’s not working. I’m not sure why, I also do t know the first thing about electrical systems .
Just curious if someone could point me in the right direction. Also curious what system other people have in place.
I installed a USB charge port and will install one more.
https://www.amazon.com/MICTUNING-UC...ocphy=9031173&hvtargid=pla-537358126269&psc=1
I did disconnect the led lights tho.
and kinda cool if you don't have a battery charge meter
https://www.amazon.com/MICTUNING-Ch...JVVCVRG1GSJ&psc=1&refRID=3XNG48PVJJVVCVRG1GSJ
Here's a dude installing it in his 4th gen. Not sure why its installed upside down - I would take a dremel to it to get it to fit correctly - my ADD would kick in to overtime. Also looks like his hole for the switch got butchered a bit. YouTube
Do you have the power switch turned on? On my truck there's a switch to the left of the steering wheel to turn it on. Maybe test your plug with an a/c volt meter or lamp with a low watt bulb in it. Beware they do not put out much for power. Generally better to use a DC one like listed in post 2 as what you would be doing is going form DC to AC then back to DC, you lose wattage each time.
