T tahoe22 New member Mar 29, 2017 #1 Any quick fix ideas? Yeah, I just failed my CA smog test due to it.
ltsr New member Mar 29, 2017 #2 tahoe22 said: Any quick fix ideas? Yeah, I just failed my CA smog test due to it. Click to expand... If it's just the bulb, easy fix. But you give us no other information besides that it's not working. Here's a thread that shows you how to replace the bulb. http://www.toyota-4runner.org/3rd-g...-climate-control-dash-bulbs-2000-limited.html
T tahoe22 New member Apr 19, 2017 #4 Check engine bulb identification Is there an easy way to identify which bulb it is that the check engine light relies on? Thanks
Tinigunner11 New member Apr 19, 2017 #5 tahoe22 said: Is there an easy way to identify which bulb it is that the check engine light relies on? Thanks Click to expand... It's the one that plugs into the the check engine light slot in the back of the gauge cluster. Once you pull out the cluster it will be obvious.
