Mauriciooo_R
In for a twin compressor. Pump up kit too if they are available. Thanks
If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
Please put me in for the CKMA12
im in for CKMTA12 and a tank
I’m in for a dual compressor.
Holy Crap!
Holy Crap!
yeah that's bad. Ill give the vendor a heads up.
I believe two other people received a damaged compressor.
Don't worry, you'll get a replacement. :typing:
Thank you ramonortiz55
Those pictures of that box are pretty pathetic right there!
My box wasn't quite in your shape, but my compressor was just loose in the box to move around and the outside of the box was torn pretty bad (I assume from the compressor being jossled around in there tearing the box). I wasnt really sure how the compressor was still in there honestly. I won't know if the compressor works until I install it in a few weeks or more. May have to just do a quick dry run with it before getting to the actual "install" just to see if everything is on the up and up with it.
Must these be installed under the hood?
I'd think that high temperatures could shorten the life of these compressors.
How about under a seat? Passenger? Passenger rear?
