**CLOSED** - Cook Partner Group Buy Spring 2018
Status
Not open for further replies.
ZOMBRNR
Hello all,
I'm working with Endless Horizon Outfitters on a Partner Steel Cook Partner group buy!
We need 15 people minimum to get this thing going. Once we've reached the 15 person minimum, I will need to get each members Full Name, Shipping Address, and final order. We will then send you an invoice, once everyone is paid, the stoves will be shipped out. Please reply to this thread to add your name.
***NOTE***
These stoves are designed to use the larger sized (5lb or bigger) propane bottles/tanks, so you will need the 1lb bottle adapters if you wish to run the small 1lb bottles.
Who: Endless Horizon Outfitters
What: Cook Partner 16, 18, 22" Stoves with or without windscreen, 1lb propane bottle adapters, all size griddles
Shipping: $30 flat rate to the lower 48
When: 2 weeks. Now until April 30th.
Pricing: Please PM, but it is Excellent!
16" & 18" 2 Burner Stove
cr=w:360,h:180
These 2 burner 16" and 18" wide stoves are half the weight of the full 4 burner stoves, and can still be used with a stove stand. The only difference between these stoves is the 16" stove will fit in a 25mm ammo box and the 18" will not. 13 lbs, 12 x 18 x 3 1/2. Burners are 9 1/2" apart. This stove can not be fit with a break-apart hinge to remove the lid. A Partner Steel carry bag is available for when the stove is not in use. Windscreens sold separately If you have a preference, you can specify gas connection either on the left or right end.
22" 2 Burner Stove
rs=w:360,h:180,cg:true
Our newest stove is 22" wide. We have incorporated some important features requested by users. This stove has the burners spaced 12" apart to more easily accommodate 10" pans. Additionally, the grill spacing has been reduced over the burner plates so that a small coffee cup can be warmed. The windscreen is a standard feature with this stove. Griddle and stand is available. 12 x 22 x 3 1/2, 17lbs. A Partner Steel carry bag is available for when the stove is not in use. You can specify the gas connection on the left or right end.
1lb Propane Bottle Adapter
This bottle adapter is required to use a 1 lb. propane bottle with a Partner Steel stove.
Griddles
cr=w:360,h:180
Partner Steel griddles come in anodized food grade aluminum that forms these durable griddles is hard anodized with a tough coating that makes cleanup easier and promotes even heating. They are rectangular and feature 1 1/4" sloped sides with welded handles on the ends. These griddles heat rapidly and clean up easily; anodized surface means that a steel spatula won't scrape off the finish.
Reserved for interest list:
1. [MENTION=109154]Brandoc[/MENTION]0mmando - 22" w/1lb Adapter, Medium Griddle
2. [MENTION=139642]TacoLand[/MENTION] - 22" w/1lb Adapter
3. [MENTION=56284]Chrisinvermont[/MENTION] - 22" w/1lb Adapter, Medium Griddle
4. [MENTION=117961]raptore[/MENTION] - 22" w/1lb Adapter
5. [MENTION=86920]mjohns2[/MENTION] - 22" w/1lb Adapter
6. [MENTION=217430]SurgicalApple[/MENTION]
7. [MENTION=153476]Peadog[/MENTION] - 22" w/1lb Adapter
8. [MENTION=117588]ElysianComrade[/MENTION] - 22" w/1lb Adapter, Medium Griddle
9. 5150Bronco(TW) - 22" w/1lb Adapter, Medium Griddle
10. [MENTION=136471]hstexan[/MENTION] - 22" w/1lb Adapter
11. jowybyo(TW) - 18" w/1lb Adapter
12. [MENTION=135639]bigears2303[/MENTION] - 22" w/1lb Adapter, Medium Griddle
13. [MENTION=169146]sactown[/MENTION] - 22" w/1lb Adapter
14. [MENTION=216731]Gxblade1[/MENTION] - 22" w/1lb Adapter
15. [MENTION=211118]TCLLC[/MENTION] - 22" w/1lb Adapter
16. [MENTION=127401]Krayziekid[/MENTION] - 22" w/1lb Adapter
17. [MENTION=80103]ColoradoFrosty[/MENTION] - 18" w/1lb Adapter, Small Griddle
18. [MENTION=144133]JPOVS[/MENTION] - 16" w/1lb Adapter
19. [MENTION=152816]rlarroque[/MENTION] - 22" w/1lb Adapter
20. [MENTION=149040]5280 TRail-Runner[/MENTION] - 22"
21. [MENTION=131171]clydeepants[/MENTION] - 22" w/1lb Adapter
22. [MENTION=122940]ramonortiz55[/MENTION] - 22" w/1lb Adapter
23. [MENTION=212916]AZFIRERUNNER[/MENTION] - 22”
24. [MENTION=128575]Stevee[/MENTION] - 22" w/1lb Adapter
25. [MENTION=88643]skaterpdx[/MENTION] - 22" w/1lb Adapter, Medium Griddle
26. [MENTION=67802]nglayton[/MENTION] - 22” w/1lb Adapter
27. tslick(TW) - 22"
28. [MENTION=198385]TrDpRo_J[/MENTION] - 22" w/1lb Adapter
29. MachineGun1987 (TW) - 22" w/1lb Adapter, Medium Griddle
30. RisingWithoutWings (TW) - 22" w/1lb Adapter
31. RJW (TW) - 22" w/1lb Adapter, Medium Griddle
32. [MENTION=47794]Aznwolf118[/MENTION] - 22" w/1lb Adapter, Medium Griddle
33. [MENTION=167387]geoalesolo[/MENTION] - 22" w/1lb Adapter
34. [MENTION=90863]whte4r[/MENTION] - 1lb Adapter
35. [MENTION=29290]matt922[/MENTION] - 18" w/1lb Adapter
All invoices have been sent!
Just an FYI on their stoves. They're designed fit a 5lb or larger propane tanks. So if you plan on running a smaller propane tank like the Coleman brand you can find at Wally World you'll need an adapter.
Thanks for noting this Mike, I'll update the first post so everyone is aware.
We can do special pricing on the adapters as well if needed!
Was just on a camp trip over the weekend discussing these with a buddy. Very interested in a 22" with adapter...sent PM for pricing
Wow talk about perfect timing. Seriously considering picking one up. What size do most people seem to go with? 22"? 18"? I am using an old gas coleman grill and have no idea what size it is, but I don't want to get something too massive!
I'll try to give a little advise on these stoves since I've had a couple of them. If you're on the fences about trying to decide on the 18" or 22". Do yourself a favor, and get the 22" stove. The 18" is a bit small if you're wanting to use both burners at the same time.
Mike
In please. 22" with Adapter
Sign me up!
I'm in for a 22".
I was just looking at these. PM sent.
Mike
All PM's replied and list updated. Thank you all!
Thanks for the advice Mike, i was going to say the same. Might as well go big so you can use 2 large pans.
I've updated the first post as well with some dimensions.
16/18" Stove - 13 lbs, 12 x 18 x 3 1/2
22" Stove - 17lbs, 12 x 22 x 3 1/2
Status
seltzernator
