Coolant Temp Sensor replacement: crush washers?
Mudeprived
I did a bit of reading on replacing the coolant temp sensor and it appears I need to remove the fuel rail jumper and it was recommended that I replace the crush washers. I cannot seem to find the part number for these crush washers.
Does anyone know the numbers?
I believe the Temp Sensor is 89422-35010. Correct me if I am wrong.
Anything else I should replace while I am at it?
fuel rail crush washer 90430-12026.
seltzernator
