cornfed
oh boy
installed cornfed on sunday towed boat on wed check engine light and vsc on and off lights lit on thur
going out to reset now ill be back
More than one person has had to do a reset... Did you make out ok on the swaybar? I don't have a lift but I vaguely remember with a 3/2 that front ABS wires could get pulled. I think the fix was simple, something like a minor reroute of the wire. I don't know more than that. I point it out though 'cause if your VSC doesn't reset I'd look at that. And as I get older the CRS (can't remember squat) is getting brutal. It may some other type of 3" front lift that had this problem.
Good luck and welcome to the forum.
:cheers:
dont think the reset pattern works on 05s tried multiple times w/ no luck anybody got any info b4 i go to dealer?
ok i have to admit i am not the best mechanic. this was the largest project i have done b4 this i changed brake pads for the first time 6 mos. ago
i got the sway bar back on you just have to lower the truck back to the ground, duh.
all of the vsc lights have turned off? i dont know why.
Sounds good:D
patnewton
