At a minimum, I need to replace my front coilovers, as both of the OEM Bilstein coil springs on my 2018 TRD Pro have completely broken with only 52,000 miles. I've spent several days researching suspension options, and I don't feel much closer to making a decision than when I started.
Current Setup:
I'm looking for something that performs at least as well my original "Bilstein" TRD Pro suspension, preferably better, while improving long-term reliability and minimal maintenance requirements. I need to maintain the current ride height to keep the wheel/tire combo, which did not require any other modifications to fit without any rubbing. Although, I am looking at aftermarket wheels too.
Options I've been considering include:
I'm not necessarily looking for the least expensive option, nor do I mind spending more money on a quality suspension. However, I don't particularly want something that requires frequent rebuilds or maintenance to maintain its performance.
For those who have replaced their original TRD Pro suspension, what did you ultimately go with, and how does it compare to the OEM setup in terms of ride quality, handling, performance, and longevity?
Would you purchase the same suspension again, or would you go a different route?
Any firsthand experiences or recommendations would be greatly appreciated.
Current Setup:
- 2018 Toyota 4Runner TRD Pro (OEM "Pro" Bilstein suspension)
- Cornfed 2"/1.5" spacer lift
- LT285/70R17 Nitto Ridge Grapplers on OEM TRD Pro wheels
- GOBI roof rack
- C4 Fabrication rock sliders
- C4 Fabrication front bumper with winch
- OEM Bilstein TRD Pro suspension that was installed on my 2018
- OEM FOX TRD Pro suspension from the 2019+ models
- Bilstein 6112/5160 (I think this might be the same as OEM)
- Ironman 4x4 Foam Cell Pro (recommended by my local shop)
- Eibach Pro-Truck Stage 2R
- ICON
- OME
- Others?
