Crank Pulley Holder
alumarine
Member
Does anyone know if the crank pulley holder for the 5VZ-FE is the same as the one for the 2cnd gen 3VZ-FE?
I made one for the 3VZ-FE and am hoping it's the same.
thanks
Larger bolt pattern on the 5vz. I made one 12yrs ago and had to drill another hole for the smaller 3vz bolt pattern
Thanks for the info.
Hopefully I can modify my current one.
Do you know if the center bolt is the same size.
That's would be the harder hole for me to modify.
Mine was made from 3/8" thick flatbar, 2" wide by 18" long. Appropriate holes drilled for socket and bolts/drill bits to fit thru
2001ATL
