Dash Accessory Mount | 2010+
Victory 4x4
Official Vendor
Our Dash Accessory Mount is now available!
4Runner Dash Accessory Mount | 5th Gen (10+)
Our DAM mount is designed to be a flexible solution to mounting navigation and communications gear onto the dash of your 4Runner.
  • CNC cut and formed from 1/8" steel.
  • Designed to use RAM® Diamond Ball Bases or RAM® Tough-Ball™ with 1/4"-20 x .50" Threaded Studs in various holes and slots on the top and front.
  • Pre-terminated remote dual USB port included (three-foot lead for flexibility in connections to either a 12v adapter or hardwire under the dash.)
  • Includes mounting hardware.
  • Some drilling required.
  • Proudly designed and made in the USA.
4Runner Dash Accessory Mount | 5th Gen (10+) - Victory 4x4
If you want/need to replace the radio, how do you remove this without damaging the dash or leaving adhesive residue on the dash?
Once installed, you can remove the bolts that hold the adhesive bracket on. That will remain attached to the dash, you can swap the radio, and then reinstall to that bracket.
seltzernator
