do these headlights all fit an 07?
I did the "does this fit your vehicle" and it said yes, but, I understand why you ask as I had items show up wrong before.
I think the difference between 06 and up verses below is that the signal light is in our headlight housing and the other models don't.
Hope that helps.
Hope that helps.
Yeah.
'06-09 also uses projectors rather than reflectors.
/\ yeah that too. I only did a check on one at the time, 2 yes, 2 no now... Bummer I like the look of #2.
Oh shit,,, got a Ninja on my a$$ now...
haha, you have nothing to fear.
OP
These two should fit w/out problems
Robot Check
Robot Check
The other two are missing a turn signal and your bumper trim piece won't clip on correctly I think. I just converted from 03-05 headlights to 06-09 headlights on my '04.
The '06-09 headlights adds a turn signal, projector AND it has a hole that the bumper trim piece clips into. The '04 doesn't have the hole and the trim won't fit w/out modifying either the headlight or the trim.
2nd and 4th fit 03-05. 1st and 3rd fit 06-08. Shape of light is different.
OP
Robot Check
Robot Check
Thanks everyone for the help, you guys are saying different ones fit. Does anyone know for sure?
yes, 1 & 3 are for 06+. look at the bottom of the lights. if its flat you cant use it. 2 & 4 also state for 03-05.
Jhunt
