Does Toyota Sell Color Keyed Side Mirrors?
luke87gt
Hi guys,
I have a 2006 4Runner that's natural white with black side mirrors.
I was wondering if Toyota sells white side mirrors for the factory? If not, what finish does Toyota sell?
I'm debating between having mine painted white Vs buying new, but need to first check pricing between the two.
Any part number info would be helpful.
Hi guys,
I have a 2006 4Runner that's crystal white with black side mirrors.
I think it may be cheaper to get your mirrors painted.
BUT
Yes Toyota does sell color coded exterior mirrors, I'm guessing your paint color is White Pearl since there isn't another white listed for 4th Gens, it also doesn't say if these are the heated or non-heated mirrors.
These are the best prices I have seen by a few dollars but you can do a search with the part numbers to see if you can find a better price, also if you decide to order new painted mirrors I would suggest contacting the seller to make sure these are heated mirrors or not before placing your order.
I looked for mirrors for the Sport/Limited model, I see you have a XSP, which isn't listed and the mirrors would probably be only listed/sold as black anyway since that's what came on your T4R XSP.
Left/driver's side..... https://toyotaparts.bochtoyotasouth...1bm5lciZ5PTIwMDYmdD1zcG9ydCZlPTQtMGwtdjYtZ2Fz
Right/passenger's side..... https://toyotaparts.bochtoyotasouth...1bm5lciZ5PTIwMDYmdD1zcG9ydCZlPTQtMGwtdjYtZ2Fz
Here's a link to all mirrors listed for your T4R.
https://toyotaparts.bochtoyotasouth...l-v6-gas-engine/body-cat/outside-mirrors-scat
Thank you for the reply.
There were two whites available:
03-09: Natural White (color code 056)
08-09: Pearl White (color code 070)
To the eye, there isn't a huge difference between the two. The Toyota Pearl isn't like Lexus pearl which looks very different than white.
http://www.toyotareference.com/4runner/2003-2009
The Toyota pearl white is a rarer color offered only in 08-09 and the vast majority of white 03-09 4runners you see out on the road are "natural white"
I wonder why your link isn't showing mirrors for the natural white color?
In any case, at just over $200 per side, I'm betting that it probably is more cost effective to paint my existing mirrors rather than buy new, like you said.
I couldn't say why the other white isn't listed unless they don't have the other white mirrors for sale, just trying to help you out.
Hi guys,
Yes they do. Call or go the dealer and give them your vin # and it will be painted to match
Toyota 4Runner Touchup Paint Codes, Image Galleries, Brochure and TV Commercial Archives
I think you should buy new and sell me your current mirrors.
:sorry:
I did my 08 SR5. The part numbers you need for both mirrors are:
87910-35630-A1
87940-35630-A1
They are the 056 paint code.
Put the codes into Google and find out which dealer will sell you them the cheapest. Camelback Toyota works for me. These is a ?% off somewhere on the TacomaWorld forum for Camelback; it alludes me now but I will find it.
https://parts.camelbacktoyota.com/partlocator/index.cfm?siteid=214329
I have all of the part numbers to change the door handles, grill, mirrors, and the part above the license plate over to 056 paint code.
Edit: Found it!
Coupon Code: TWpartz
Tacoma World members receive a 3% off order
It should still work; haven't tried it for a while. Might check them out on TacomaWorld.
http://www.tacomaworld.com/forum/
hoodoo, great info, thank you for sharing!
I ended up buying the grill new on eBay and the door handles new from Toyotapartsdeal.com (I see the prices are today just slightly different than what I show below). Here are the part numbers I ordered:
White Limited Grill:
53100-35A03-A0
White Door Handles:
Handle Main Assembly
69211-28070-A2 x 4 -> $27.74 each
Handle Sub Assembly
69217-60020-A0 x 1 (PF) -> $7.53 each
69217-28010-A2 x 1 (DF) -> $5.60 each
69227-60020-A0 x 2 (PR and DR) -> $7.53 each
Pads that go between handle and body
69241-28060 x 4 -> $0.82 each
69242-60030 x 4 -> $7.67 each
The trim piece above the lic plate I bought used on eBay and installed it yesterday. Install took about 30-45min.
Let me know if all those numbers above are consistent with what you are showing.
Also, for the pads that go between the door handles and body, I assume those are always black? you can just barely see them peaking from under the door handles. I was wondering if those come available in white. Does anyone know if the White 06-09 Limited/Sport comes from the factory with black pads under the handles?
Thanks again guys!
:sorry:
Tell you what, if you order me a new white driver side mirror to my door, I'll give you both of my blacks ones off my 2006.
PM me if interested.
Hey Luke.
Here's the numbers I got:
COVER, FRONT DOOR OUTSIDE HANDLE, LH
Part Number: 6921728010A2 (1)
HANDLE ASSY, FRONT DOOR OUTSIDE, LH; HANDLE ASSY, FRONT DOOR, OUTSIDE RH; HANDLE ASSY, REAR DOOR OUTSIDE, LH; HANDLE ASSY, REAR DOOR OUTSIDE, RH
Part Number: 6921128070A2 (2)
COVER, FRONT DOOR OUTSIDE HANDLE, RH
Part Number: 6921760020A0 (1)
COVER, REAR DOOR OUTSIDE HANDLE, LH; COVER, REAR DOOR OUTSIDE HANDLE, RH
Part Number: 6922760020A0 (2)
Looks like you need the cover for the driver's door?
Getting closer to doing this swap.
Need to spend some time probing around this site on how to get the door panels off to get familiar with it.
If anyone has a youtube link, that would be awesome.
FWIW, I had black mirrors on my SR5 but just took them off (which is easy) and apart (really nothing to it if you have a screwdriver) did a few stages of sanding, primered and painted with color matched paint then a few coats of clear coat. I ordered a kit off scratchwizard.net for like $40 and it came with everything--sand paper, primer, paint and clear and was enough to do both mirrors.
Really can't even tell they didn't come that way. For the money, probably the best upgrade I've done aside from plasty-dipping the grille black (left the badges alone).
Just an FYI I talked to my local paint shop that I have used in the past and they stated 2-250 for both mirrors. So might want to call your local shop.
Happen to have a link to that kit you ordered? Thanks
044runner4
