Double Decker?
1morecast
I'm still trying to figure out which cargo mat to buy. I have an '06 Sport Edition with no third row. I dont know about the Double decker thing. Could someone explain. Thanks
You mean you don't know what the double decker cargo is? It is a shelf that you can raise and lower in the very rear...if you don't know what it is, you more than likely do not have it.
Double Decker
I have the "Double Decker" system in my 4Runner and was so happy that I bought one with it; but have never used it. I suppose it may help when I sell it, though.
:bash:
FYI, the cargo area underneath the deck (raised position) is not the same as when the deck is lowered. So a liner designed to fit with the deck in the lowered position will not fit under the deck when it's raised.
If you don't have the double deck or even if you have it, I'd recommend the Husky's.
You have the double decker, if there is a tray like area behind the wheel wells and center area of the cargo floor is higher. Also the the edge trim at the back door is about an inch or so lower than the cargo floor and the cargo floor edge is rounded off (it rolls down towards the trim). The carpeted area should be a rectangle. Non double decker trucks will have carpet behind the wheel wells, a T-shaped area that's completely carpeted.
There are mats specifically designed to go over the shelf and others that go under. I thought I would use it more then I do.
Koz
I definitely dont use it as much as I thought either...but I am very happy I did not get the 3rd row seating.
Now that we are talking about the double deck floor I have a small complaint about the design. About a week after I bought the truck I picked up a flat of beer (4 six packs, botlles) and put it in the back. When I opened the lift gate the beer was resting against the back and due to the rounded design of the edge of the deck the flat slid right out and hit the driveway. I lost 8 Stellas.
Sad sad day.
Ive never used mine, but it doesnt bother me that it is there. I have the husky liner that covers it so it isnt very easy to use. 67 Mustang, sorry for your loss, gotta use the cargo nets.
Sad sad day.
Cargo net!
http://newtoyotaparts.com/product/?id=1912
Koz
Sad sad day.
Definitely get a cargo net. I use that a lot more than the double decker.
quote:
Sad sad day.
Cargo net!
Koz
Check out eBay....a little cheaper there than Carson Toyota....Conicelli Toyota has incredible prices for parts on ebay compared to others....and if they aren't listed they will get it for you....
