Even if I get a new retainer ring pressed on, how will it not just have the same problem? Are you saying that Toyota changed the seal so that it won't work properly? I don't exactly have the cash to shell out on the full wheel bearing job right now, would it be possible to just replace the one retainer ring that the seal rests on?
No, what I'm saying is that if you just replace the seal and do nothing else, the seal lip will be riding very close to the bevel of the inner retainer. Your bearings probably have a lot of miles on them and will allow some in and out play of the axle shaft. Because of that axle play, the seal lip will end up riding on the non-polished bevel part of the time. The bevel is not a polished surface and will prematurely wear out the seal.
A big reason why axle seals fail is due to worn out bearings that allow excessive movement in the axle shaft and thus extra strain on the axle seal. It's not just in and out movement but up and down movement as well. Over time, the old seal can't handle it and it fails. The new seal design is an improvement over the old design because it's more pliable and will handle more movement in the axle shaft.
If you're short on cash, your best bet is to replace the seal and reposition the inner retainer so the seal lip rides more near the center of the polished shoulder of the retainer. Some people keep the retainer in the original orientation, bevel facing the seal and just move it more inboard around 2mm (3mm of polished axle showing above the retainer). But, when you do this the inner retainer is now going to be coming very close to rubbing the inside of the axle housing. This is why I like the flipped orientation method. You get to keep the inner retainer in the same position as before on the axle (5mm of polished axle showing above the retainer).
Whether you do it yourself or have a shop do it for you, be very specific how you want them to press on the inner retainer. If you take it to a machine shop and they say they usually cut the parts off, I'd suggest you look for another shop. It's very common for shops to accidentally score the axle shafts by not being careful when cutting off the parts. The preferred method is to pull them off.
By repositioning the inner retainer and installing a new seal, you can buy yourself some time but ultimately you may have another failure because that worn out bearing is putting extra strain on the seal and it will eventually fail. This is why any shop is going to suggest you replace the bearing because it could very well be the cause of the seal failure in the first place.
