Duratracs 265/70/17??
T4R03
Stock suspensions 2003 Sport Edition. Getting duratracs tomorrow. Will 265/70/17 cause any rubbing or issues?
Won’t rub ... it’s not a big tire , 31” you will be fine assuming stock rims
I don’t know about Duratrac but I just got the falken wildpeaks on my v8 limited stock suspension and I rubbed quite a bit turning left only. I used a heat gun and pushed the fender liner forward and it made things better. Getting a lift soon so that should fix everything.
Your rims offset, etc also play a factor on whether you’ll rub or not. I’m running TRD PRO rims with 0 offset I believe.
