Eibach Load Leveling System (aka height adjustable rear)
Ryan at Eibach
It's finally ready to rock, Fellas!
Developed for vehicles equipped with solid-axle coil spring suspension, the Eibach LOAD-LEVELING-SYSTEM uses a combination of readily available Eibach Race Springs, adjustable threaded spring seat and bump stops to allow fine tuning of load capacity and ride height. Engineered and tested for each application, the LOAD-LEveling-SYSTEM is available in three different load ranges to achieve up to 2.5" of lift for maximum travel and tire clearance off-road.
Features
Available in 3 load ratings: 0-200 lbs. / 200-400 lbs. / 400+ lbs.
Eibach ERO compatible using our commonly found 3.75”ID Off-Road Race Springs
6061-T6 billet aluminum threaded spring seat for corrosion resistance and easy adjustment
Hi-Durometer polyurethane spring seat isolator reduces NVH through axle
Progressive polyurethane bump stop system improves control over large bumps
Spring seat, bump-stop relocating adapters and hardware included for easy installation
Made by Eibach in the USA
Follow this link for all the details:
Rear Ride Height Adjustable Load Leveling System | Eibach Springs
Developed for vehicles equipped with solid-axle coil spring suspension, the Eibach LOAD-LEVELING-SYSTEM uses a combination of readily available Eibach Race Springs, adjustable threaded spring seat and bump stops to allow fine tuning of load capacity and ride height. Engineered and tested for each application, the LOAD-LEAVING-SYSTEM is available in three different load ranges to achieve up to 2.5" of lift for maximum travel and tire clearance off-road.
Features
Just and FYI - there's a typo on the website. Same as the copy here. I highlighted in red.
Also - this looks like a great option. Nice work.
Great Work. Eibach has the best customer service in my opinion, which is why I've been waiting for this as a kit. As soon as Ryan say's it available as a complete kit. I'm in.
Just for clarification, this includes the springs? Is there a way to just purchase the other components if I’m already running Eibach springs?
This includes new springs. Your current springs will not work with this kit. The new springs allow you to choose spring rate based on your load.
If you get the 200lb. Load range, and have a 200lb load in the back, the minimum lift is 1.5" if I'm reading this right (based on the website):
Load Capacities & Height Ranges
200 lbs/in Loaded Height Ranges
Additional Weight Lift at Full High
0 lbs 2.0"
100 lbs 1.75"
200 lbs 1.5"
250 lbs/in Loaded Height Ranges
200 lbs 2.5"
300 lbs 2.25"
400 lbs 2.0"
300 lbs/in Loaded Height Ranges
400 lbs 2.5"
500 lbs 2.25"
AndiGarage
