Eibach pro truck lift first vs second notch install
I just finished to install an Eibach pro-truck lift and questioning myself if I go second notch or I leave it like it is now. I ran the truck for 20 km before any measurement (enough?), now I have 37" front 38" rear and it shows, I would like it to be more level so should I go second notch? I call the community. :biggrin1:
Measuring from the fender well is deceiving. Have you measured from the bottom of the frame rail to the ground front and rear?
The lift will settle little bit as you drive it.
I personally prefer to maintain a little rake as I occasionally load the rear end and tow.
Helps keep the headlights from aiming at the sky and when driving it doesn't look lopsided.
2nd notch is supposed to push it to around 3.4". Any of the other higher 2 notches are there in case you add a lot of weight, like a bumper. I would say wait a bit and see if it settles at all.
Sent from my SM-G965U using Tapatalk
seltzernator
