tatooweeny
So I've had my 89 4Runner (22RE) now for awhile and I've had little electrical problems here and there, mostly from shoddy wiring from the previous owner (Stereo hack job), but every time I fix one problem, another arises. Let me elaborate.
So the first issue I had was the brake lights not working and the "brake" light on the dash permanently on. We found a pinched wire under the dash that fixed the brake lights not coming on, and when we adjusted the emergency brake, it seemed to fix the "BRAKE" dash light.
Then the "ALT" light along with the "BRAKE" light came on. They seemed to go on and off at the same time, which was weird to me. So we traced the issue to being the battery cables.
The previous owner had put a battery in that had the posts in the front, not the rear, so they had extended the cables using an extra set of wires loosely bolted together along with wrapping everything with electrical tape - very professional, Lol.
The cables were brittle so we replaced the battery with a yellow top Optima (plan on some cool accessories later), along with upgrading the battery cables to the starter, engine ground and chassis ground. That fixed the dash lights again.
Everything was now working including the rear window, which before replacing the battery had trouble rolling up and down.
Last night I'm driving home and the "CHECK ENGINE" light came on. When I stopped at a light, it was idling rough like it wanted to quit, but never did. When I got home I checked under the hood to see if I noticed anything out of place; was hoping for an unplugged wire or loose connection but couldn't find anything. I was tired and cranky at that point.
This morning I start her up and the light is still on, but idles smooth even under load. Still cannot find anything noticeable under the hood.
I plan on taking her to my local shop today to find out what the error code is. I'm hoping it's nothing major.
Any advice as to what it could be? I know it could be a million different problems, but maybe it's linked to something I've done.
