Elka suspension! [in stock]
Battle Born Offroad is proud to annouce we now carry Elka!​
The 2.5 DC RESERVOIR model allows precise fine-tuning of the high-& low-speed compression damping so you can adapt the suspension for your specific driving style and terrain conditions without compromise. It also features an external reservoir with increased oil volume for cooler operating temperature, providing better performance and consistency.
Increase the off-road capabilities while improving the comfort and handling of your 4Runner
ADJUSTMENTS
Spring Preload
High-Speed Compression
Low-Speed Compression
BENEFITS
Wide range of highly effective compression adjustment
Precise fine-tuning of high-& low-speed compression, no need to compromise with your settings
High-performance off-road capabilities
Improved handling and comfort for casual driving
Better traction
Provides leveling capabilities for better weight distribution
Increased protection against bottoming-out
Better attenuation of vibration, leading to major noise reduction in the cabin (much less squeak and rattle)
TECHNICAL FEATURES
Massive 2.5 in. (56mm) hard-anodized aluminum body for cooler operation
Big bore design with less restricted oil flow for increased responsiveness and less fading
Internal hydraulic valving optimized for each vehicle platform
Built from CNC-machined and forged aluminum parts, aluminum bodies and premium-quality internal components
External remote reservoir with low-friction floating piston (1:1 ratio vs. main piston) providing additional cooling
DOT high-flow reservoir hose
Heavy-duty 3/4 in. (19mm) induction-hardened shaft
Triple sealing system with dust wiper, high-pressure step-seal and premium quality o-ring
Direct, bolt-on replacement that uses stock shocks location
Proprietary ultra-low friction, light viscosity semi-synthetic oil blend, ultra-resistant to high operating temperature
Coilover models use Elka’s durable high-tensile alloy springs or Eibach springs (depending on model & configuration)
Fully rebuildable using affordable replacements parts and springs, multiple replacement valving shim stacks available
We currently have 2 full kits in stock and more on the way! these are hard to beat especially at the introductory price we are including,
Elka has been producing high quality shocks for over 20 years we find it surprising that not more people running it, we believe these will be a major contender over the next couple years in the toyota world, Be the first to run this awesome set up!
We are offering 10% off!
Use code ELKA10 at checkout
2010-21 toyota 4 runner Elka DC 2.5 coilover:
PURCHASE 90142 - ELKA Toyota & Lexus - Battle Born Offroad - The #1 Las Vegas Offroad Parts Store!HERE
If you would like to pair this with control arms or any other components feel free to send us a message direct or you can email me direct at [email protected]​
2001ATL
