Emergency kit from cost-co
Both look pretty nice. The AAA kit looked like the items are of better quality but what can you tell from a picture. I personally would make my own kit. That way I can spend more or less on items in the kit I want of better quality or less on things I would use less or never.
gizmopt2002 said:
I am debating between Justin Case road kit http://www.costco.com/Browse/Product.aspx?Prodid=11120334&whse=BC&topnav=&browse=&s=1
and cost-co AAA deluxe emergencey kit http://www.costco.com/Browse/Product.aspx?Prodid=11045796&whse=BC&topnav=&browse=
which one do you guys recommend? Thanks in advance.
Yep, build your own, especially if you can spend a little more and get better heavy-duty jumper cables as well as a kick-a** tire pump/compressor from Pep-Boys or others.
Re: Re: Emergency kit from cost-co
teotwaki said:
Yep, build your own, especially if you can spend a little more and get better havy-duty jumper cables as well as a kick-a** tire pump/compressor from Pep-Boys or others.
:bigok:
Yup I agree. Also If your ever going to be driving in heavy snow especially out in the sticks I'd add a shovel and maybe some gravel for traction in ice.
Also maybe a tire plug repair kit. I didn't see that.
Get a good 400 or more amp booster pack/with a built in compressor from sams or costco.
If you ever want to air down ther is no need to drive to a gas station anymore just fill em back up.
Re: Re: Re: Emergency kit from cost-co
Mr. Lambdebois said:
:bigok:
Don't buy a combo unit if you can afford a separate compressor.
SuperFlow MV 50 and MasterFlow MF-1050 are awesome units and can air up your tires in no time. See this link for more.
http://www.gearinstalls.com/pepboys.htm
Re: Re: Re: Re: Emergency kit from cost-co
I've be searching pep boys for one. After 3 stores, I found only one on the shelf. $69.99 And it was used/open box. :bash:
Prictio
