Engine stutters when headlights come on
Yaddle
I've got a strange problem. My 87 4Runner's 22RE stutters nearly every time I turn the headlights on. For just a second it seems to miss a spark or two. It's a brief but pretty severe drop off, enough to see the RPMs drop by a couple of hundred on the tach. I just sort of shrugged it off until it nearly killed it entering the interstate a few days ago.
The battery is only a week old, and it did this with the old one, so I can eliminate that. I've also already replaced the wire that runs from the positive battery terminal to the fuse box with a piece of 8 gauge battery cable.
Has anyone experienced this? Any of you T4R gurus have a clue what could cause this?
... I've also already replaced the wire that runs from the positive battery terminal to the fuse box with a piece of 8 gauge battery cable.
Check the rest of the pos and neg (ground) wiring to be sure the connections are clean and tight.
Alt to battery +, battery - to body, body to engine block, body to frame.
The next thing to consider is the alt itself, are there any other signs that could point to a problem with it?
tuṣṭāva
