Exterior Side Accessory Panel NOW AVAILABLE!
Why is the gas can upside down - that doesn't look like a good idea.
It can be mounted in any orientation (vertically, horizontally, and a number of angles). We plan to run a water can with a spigot this way so it's easily accessible.
Maybe it would be worth it to extend it down to the body... then you could just have it rest on the paint with soft pads, suction etc. Might be safer than the window?
Sell the suction cups (with mounting hardware) individually - so people can run more than one if they want and to replace ones that go bad.
I'll also echo the comment about more clearance at the roof line.
Seasucker has been using pump suction cups for years with great reviews. Bikes, highway speeds, a lot of leverage....
Clean glass and cup, I wouldn’t worry, especially since it is hard mounted to the rack.
The only things that jumped out to me was the roof line clearance and it would be cool if it matched the profile of the window for that 4R look. With maybe a 45 degree brake bend in front to deflect wind
SeaSucker – SeaSucker
Definitely interested if compatible with Gobi stealth.
I know Joes is solid and stands up well in different climates. If I had the right rack I would have gotten one by now. I do like that Joes covers more surface area.
But I also have not been let down by Victory4x4 yet.
Now Available!
The Roof Rack Side Accessory Panel is designed to offer additional exterior storage for fuel or other accessories. Comes coated in a 2 stage satin textured black powder coat over durable zinc primer finish.
  • Bolts to Victory 4x4 Roof Racks and securely mounts to the rear window using a vacuum suction cup.
  • CNC cut and formed from 3/16" aluminum.
  • Includes mounting hardware.
  • Mount Rotopax fuel, water, quick fist mounts, etc.
  • Will work on 4Runner (4th & 5th Gen), GX (460 & 470), & 100 Series Land Cruiser.
  • Recommended 20lb weight limit on side panel + shovel/axe etc on roof rack bracket.
  • Proudly designed and made in the USA.
Roof Rack Side Accessory Panel - Victory 4x4
Wow These are Hideous and the fitment looks pretty awful... so far from the roof at the top, 1 suction cup, and that window contour.. really?
You couldn't shape it a little more like the window and put 2 cups? the pointed corners do not flow with the 4 runner body at all.
I prefer the Joes one with the slide in suction.
Take this back to the drawing board... i have your molle rack, bumper and roof rack products but this is horrific.
Has anyone tried to mount it to a Gobi rack? I looked at the Joe’s version over a year ago and also no Gobi mount or anyone who has mounted it to a Gobi
Rack.
Emailed Joe’s equipment over a year ago and was told they’re working on something. Well still not done. Does no one make this for the SSO rack?
seltzernator
