F+r diff flush and t-case?
tylka4runner
What kind of gear lube recommended for all 3 and how many quarts for each ? Also, any tricks on doing the flushes or is it pretty straight forward ?
I've used the cheapest gear oil Walmart stocks every 50k no problems. Tips I would always undo the fill bolt first, have some kind of fluid pump will make life easier. You need a 10mm hex and 24mm socket. I used 1.75 gal of the stinky!
75w-90 is what's recommended. I switched over to Mobile 1 synthetic. I agree with getting a fluid pump. It will make life a lot easier for you when you go to refill with oil. I got a cheap one from harbor freight. Works great.
i did this last 3 days ago, plenty of threads on here in the maintenance section with pics. get the right washers from the dealer and u'll be set.
After reading through many threads, I end up using Walmart Brand fluids as well and plan to change it more often. I used 6.5 quarts.
utkrstam
