Hey all,
I’ve been looking at all of the recent lift threads and questions and decided it’s time to make my own decision on what lift to get for my 2000 Limited. Like most everyone else, I’m looking for a 3-4in. lift and am planning on throwing on some 255/85 Bighorns and 1.5in Spidertrax – I welcome comments/opinions on the use of 255/85’s and Bighorns. The truck is my daily driver (I don’t drive that much) and is also used for trips (camping/climbing/skiing) where bad dirt roads are common and occasionally a specific off-roading trip. I most likely have a budget of a little under $1000. I can’t justify dropping 1.5k on an SS 1.2 given my uses.
Here’s the setup I had in mind, based largely on Duhockey’s very helpful post:
Toytec coilovers ToyTec coilover kit with Bilstein 5100 shocks *Backorder* - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
SS “econo” coilovers Econo-Adjustable Front Coil-Over : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts
From what I can tell, the main difference is the price and shock type (Bilstein 5100 vs 5125). My question here is what is the difference between the two shocks and are they both the same in terms of adjustability?
I would need new top plate spacers, but I’ve heard you can get these easily at most local auto stores for pretty cheap. I would also add a toytec diff drop.
For the rear, I will use LC80 coils, but I don’t know what shocks I should purchase? I was thinking OME’s or Bilsteins, but I don’t know what models are the correct length etc. Also, I’ve seen quite a bit of contradicting information from various threads in terms of the different coil wraps ad how much lift they will result in. From what I can tell, 7-wrap from a 2wd give about 3-3.5in, 9-wraps from a 4wd sport give about 5-5.5, and the 8-wraps are somewhere in between (all after settling). Can anyone verify this? Also, any suggestions on places to purchase these besides looking at my local parts yard? Will I need brake line extensions with this setup?
I would love to hear people’s opinions on this setup as well as any suggestions you may have to improve it. Thanks!
For the front, I was thinking eitheronly way LC coils cost 100$ is if you are in Canada, 50$ a pair here in Denver, right around 80$ shipped anywhere in the US thru my friend Katy ROCKI TOP AUTO
no brake lines needed... the bilsteins are your best option for the rear but not your only.. I have procomps, and they work.
Pro Comp Suspension Systems 927553 - Pro Comp ES9000 Shocks - Overview - SummitRacing.com 40$ a piece for 80$ for the set... also make sure you get the lifted application ones.. same part #
these are only 600$
and top plates are like 25$ at O'reilly/checker
diff drop is 30
So, I figure
80 coils
80 shocks
600 coilovers
25 new top plates
30 diff drop
thats 815$ give or take a few bucks for tax here and there.
and thats the exact setup I have... if you spring more for bilstein, you are still just above budget
