Flatboys rear turbo build
I think it's time for some videos...
Have you had to tow anything since you've had the turbo on?
Also, where did you pick up the 0.08" restrictor for your oil feed?
I haven't towed anything, got a 93 cummins mildly warmed over for towing the kart trailer, and for the restrictor I took a an fitting and welded the end up then drilled a hole but I think ATP turbos sells restrictors.
Any chance you could take video of your scavenge pump running, but with engine off? I'm trying to get a feel for how much noise it makes. I've already ordered the same scavenge pump that you have, so I guess it's too late lol. But I'd still like to see if a video if you don't mind...
I really have no clue on uploading videos, but I'll see if my boy can give me a hand.
Space reserved for pump video.
Crapy video but you get the idea. Pump is pretty quiet, you cant hear it when the engine is running, and when you shut it off you can barely hear it and a bit of vibration you can feel.
So finally got around to modifying the trailer hitch, not that I'm goina be pulling a trailer but I hated seeing the spare tire just sitting out in the open.
hmmm cant seem to get pics up from photobucket anymore.
For final sanding I always use a paper disc with the rubber back, you can pretend your a milling machine and get it deadly flat with this set up. Im not a fan of those flap discs as they are so easy to get the metal dished out and uneven.
now to go find the rest of the pics..............dam computers
Last night I got some powder on the hitch, nice to finally get something back there. This is Eastwood 'Satin Black' color which is the same as my winter rims.
Next project is the Snow Performance boost cooler stage 2 pt#20010
