Flooded my '99 Limited, a few electrical questions
clys
So the entire interior is out of it, except for the dash. Mostly all the electrical issues I had since it flooded have fixed themselfs as I let the truck dry out, however there are 2 issues that remain.
1.The climate control says it's switching between hot and cold, but it isn't. The heater flow valve under the hood isn't moving at all
2. The drivers side front window does nothing. I took apart the master switch, cleaned it and layed it in a bed of rice for two days. Everything else works, just nothing for my window.
All fuses are good, and there were no issues before I went full re**** and flooded the thing.
Thanks in advance.
Thought is would be obvious but apparently you need the obvious pointed out
1). Could be either servo that opens and closes the heater valve or the climate control module itself is bad.
2) most likely your window motor is bad.
hey i just flooded my 99 limited runner. the engine will not start and when i re connect the battery the alarm stays on and the doors keep locking and unlocking. i was wondering if you had any of these problems and if yours started running again after letting it sit. please help me ha
