01thunder New member Sep 11, 2013 #1 what good is the internet if what you look for is not found? damn! i was looking for alignment specs for an 01 and don't find a damn thing! so who knows what the specs are? i did the 5100's in front and the camber is off.
nevada Senior Member Sep 11, 2013 #2 i can look them up if you must have them. but, whoever does the alignment would have this information. an alignment isnt generally a DIY procedure. Last edited: Sep 11, 2013
01thunder New member Sep 11, 2013 #3 nevada said: i cant look them up if you must have them. but, whoever does the alignment would have this information. an alignment isnt generally a DIY procedure. Click to expand... i know. i want to know what stock specs should be and if i can get them back or close to them.
nevada Senior Member Sep 11, 2013 #4 01thunder said: i know. i want to know what stock specs should be and if i can get them back or close to them. Click to expand... so, you have camber, and caster gauges? what im trying to figure out is, without the correct equipment, how are you going to know WHAT the settings are?
nevada Senior Member Sep 11, 2013 #5 my book is showing. camber: -25* +-.75* caster: 3.06 +-.75* toe: .08" +- .08"
