Front Bumpers for 5th Gens
Yeah I didn’t care much for the middle brush plate on my Shrockworks front bumper either. I covered mine with a mesh grill. Here is what it looks like now.
That hoop and paint match looks Awesome!
Thanks but it’s not paint. It’s powder coating. A company called Prismatic Powders has a color that matches the Toyota Quicksand. They call it Thatch Brown. It turned out to be a great match.
I sent the powder to Shrockworks and they did it for me for a extra $100. The powder cost about $50 for 5lb. They have a lot of other matching auto colors but they use different names. But each manufacturer has a color code for their paint. If you give that to them they can find the correct color for you. Then for a few buck they’ll send you color samples. Over all I was very happy with their service. Here’s the link.
THATCH BROWN
| PSB-8088
| Prismatic Powders
However in hindsight I would have order it as bare metal and powdered it after I got it. The reason is the part that goes under the headlights didn’t quite fit properly. If it was bare metal I could have grinded it a little to make sure it fits right then powder coat it. Also I would have powdered the bottom bracket that attaches to the frame and the water reservoir cover on the bottom left Matte black for a slightly cleaner look.
THATCH BROWN
| PSB-8088
| Prismatic Powders
ahhh if you sent it to SW then Precision Powder Coating did the work,
They are one of the best in the Houston area, pretty much down the street from my kid's daycare. PPC coated my spindles w/TC gussets last week and prior to that my C4 lo pro and Tacoma wheels.
Precision can accept parts and send them back to you if you give them a prepaid shipping label.
For clarification I got the actual Thatch Brown (Quicksand) powder from Prismatic Powders in Oregon. They only make the powder paint for powder coating. They don’t do any powder coating as far as I know. However, I think Shrockworks uses Precision Powders to powder-coat their products since both are in Huston.
Does anyone have experience/review for a 4runner front bumper made by Fab Four? (Hidden Winch Mount | Fab Fours)
Its one of the few I've found that does not have d-ring mounts that stick out. Figured this is better for when I park in the garage.
There is a sale on 4wparts right now just looking for a review.
(first time poster, long-time lurker and no I'm not the vendor)
Fab Four? No thanks. Why support a big box brand known for shitty products? I'd rather support a small fab shop like Shrockworks, C4, SSO, Victory, LFD, etc etc. I'd also like to see the internal frame, bracing, welds, on the Fab Fours being even considering them. Are the Fab Four shackle mounts welded inline with the frame or bracing?
The shackle/recovery mounts on lo-pro bumpers don't actually stick out that much, maybe 2" at most. It's negligible and shouldn't prevent you from fitting into or parking in a garage. The Shrockworks and C4 lo-pro mounts the shackles on the lower angled portion so they are not the most forward point.
2014-2020 4Runner Ultralight
2014+ 4Runner Lo Pro Winch Bumper | C4 Fabrication
Who makes the lightest front end replacement?
Not wanting to run a winch at this time, just a little more protection and recovery points.
Full bumper or hybrid.
Teach me the ways.
Maybe this was already mentioned somewhere in the 11 pages of this thread but I thought it may be helpful to you. If you need/want a rubber lining around the plastic where it was cut to help straight it up or like the looks, one option is McMaster 8507K16 neoprene. $15 for 10’. This is what one of the bumper manufacturers sends out with their kit for 5th gen.
Do you guys think it is a good or bad idea to use the rubber lining?
I'm trying to find a front bumper for my 2020 that has an integrated front hitch receiver and can also accommodate a winch (planning on a Warn VR Evo 10). I've searched both on these forums and elsewhere but haven't had much luck. Does anyone know if such a bumper exists?
To add to this, even a front bumper with an integrated receiver, that doesn't accommodate a winch, would be a win. Now that CBI no longer makes their high clearance front hitch, which can be mounted to be hidden behind the license plate, the only options I've found are receivers that sit below the bumper and further impact clearance.
came across a local ad at $700 for the following , seems like a good deal for c4 bumper.
C4 fabrication grey color
Model: Trail / TRD Off Road
Bull Bar Tube ($74.00): Yes - Mid Height, No Gussets
Center LED Bar Cut Out ($240.00): Yes - Extreme LED - X6S Slim Series 2D Amber White Combo 25" Single Row LED (w/harness)
Wiring Harness Options: No
Custom Text Options: C4 Fab Logo
Hawse License Plate Mount ($55.80): Yes
Looks like i'll be needing a new bumper after tearing through a concrete pole :(
looking for feedback from you all about long term use
Just logged back in after about 6m of nothing - glad to see some of the heritage folks are still around. Nothing to add other then my SSO Hybrid bumper has been excellent other then the fact the powder coating simply does not hold up to the midwest winters and the cost to get it blasted and lineX-ed is about what it costs new.
I just ordered a second set of Alu. Skids from RCI because the originals were beat beyond fixing and I ordered a set of Alu. Sliders from Greenland to replace my steel budbuilts( awesome products but I can not keep up with the rust).
I thought SSO offered a Alu. version for a short time, wish I had gotten that. I do think the Shrockworks and Demello had the best looking full replacement bumpers back in the day, not sure if that's still holds true.
I've had good luck with my Hefty Fabworks bumper. It's been about 6 years now and it's just getting to where I'll strip it and have it re coated.
Sso slimline dumper for 5 years w wings and no issues. Upgraded to a demello bumper also with no issues
Is there anyone who still makes a full front for a 2013 Limited? I am not finding much at all, but wold love to have one.
Runvod
