Front differential differences
T4R-noob
Any differences in the 2000 front diff vs a 2001. Reason being, i just picked up a 2000 limited e-locker rear end and front diff to match gearings to be swapped in my 2001 sport. Need to know if everything with swap over easily on the front diff. Thank you
The only difference between the two diffs is the actuator. Your 2001 has an electronic actuator, where the 2000 has a vacuum actuator. Swap the actuators, and viola! Everything else is the same.
Pretty sure I told you this, almost word for word, a couple of days ago :roadkill:
:p
premiumusedautoparts
