Front Receiver?
Aodhan
Trying to see if there are any 3rd gen 4runners with a front receivers installed? I tried doing a search but could not get the answer that I was looking for.
I am looking to mount the hitch/receiver on the front of my 1998 3rd gen.
Has anyone done this? or am I nuts for thinking about doing this?
Basically just looking to attached a hitch mount winch, and dont really want to go with the ARB or Shrockworks winch bumper just quite yet.
Thanks for your help and advice
Seems to me you can just weld some plates on both sides of a hitch bar and utilize the bolt holes for the tow hooks to attach to the frame.
Just a brainstorm
That looks like exactly what hes talking about. Someone just fabbed that up with a draw tight hitch. Another place you can look is like an RV place, in the towing section. RV's are always towing vehicles and they have the accessories for it.
I always like this one for the 4th gen:
http://www.toyota-4runner.org/4th-gen-t4rs/85730-new-hidden-front-receiver-hitch.html
Only thing i wasn't super excited about is that it appears to remove the factory crush zones. No worse than 99% of the aftermarket bumpers out there though.
I like the idea simply because if I purchase a winch it would be awesome to be able to use it front, back, or on a trailer with out any real work to swap it around.
Looks easy enough to fab up or contact them and see if they will make one for a third gen.
OMG!!
That looks like a way around the insurance company!!!
I m sure they dont like aftermarket bumpers... and I have a rear but dont have the balls to put a front on because im sure the insurance company would drop me if they found out....... or not insure an accident...
But with this i the factory bumper is still attached! and this is just an accesory....
SO happy i saw this!!
Zachpins34 - good find! I am thinking if I might go that route if I can not get it set up behind the bumper
Stick Figure, that is exactly what I am thinking of trying to copy for the 3rd gen 4runner. I am hoping that someone might have tried that already so I could copy their set up, but looks like I might blaze my own trail on this one.
Thanks for the help so far! Any other thoughts or suggestions about this? I don't off road a whole lot, mainly just some gnarly forestry roads in the northwest while camping, I just want the safety of having a winch in case I end up stuck somewhere.
I asked the same thing a few weeks ago and a member here(The Kid )advised me that a Tacoma is the same as our truck up front. Who knew.
I just bolted mine on tonite. I did a "google" search for Tacoma front receiver and took a look at everything that was available. Once I found one that seemed affordable, I went to Amazon and bought one. I got a Reese model 65041, but the Warn was highly suggested.
Its very simple to install.
- Remove the 4 bolts from the stock tow hook and tie downs.
- Remove the front skidplate.
- Remove the 4 lower bolts from the bumper bracket mounts.
- Grind off the back side welded nuts from the lower bumper bolt mounts.
- Put the receiver in place and bolt it in.
- My Reese had 2 additional mounting holes on the side that go into bolt
holes on the Tacoma, but our trucks don't have them. You need to mark
and drill a hole in the frame and then remove the whole thing.
- The hole that you just drilled needs to be enlarged to 11/16" and a supplied
riv-nut installed.
- Now the receiver gets bolted back in place for good, so some locktite on
the threads is a good idea.
- Bolt the skidplate back on.
- Check the front bumper cover for clearance and trim the plastic accordingly.
If you would like, I can take some pix of the installed piece tomorrow.
If you would not mind, pictures would be awesome. Sounds easy enough that I might try and do it this weekend.
Thanks for posting up!!!
riv-nut installed.
OMG!!
no insurance will drop you for having an after market bumper, or deny a claim... thats like saying because you put mud tires on your truck we wont insure it anymore...
x2 on some pictures. If you can take some of where it bolts up please do so.
I will take some pix tomorrow.
If you take a quick look under the front of your truck, you'll see where the tow hook and factory tie-down brackets are bolted on. You remove those 4 bolts, 2 on each side.
Pix after 8 tomorrow night.
Where are you located?
I got the front hitch receiver on the truck and it was an easy installation. Here's a few pix of the completed piece.
This is a shot looking up at where it mounts to the original tie-down and tow hook holes.
IMG_2001.jpg~original
This is the hole that needs to be drilled in the frame. Since the receiver is actually for a Tacoma, their frame has the hole, but the T4R does not.
IMG_2000.jpg~original
The 2 bolts that attach the front bumper mount need to be removed and eventually replaced. I haven't done it yet, but when I do I'll take and post a picture.
IMG_2002.jpg~original
The receiver needs to be ground down about 3/16" in order to clear the bumper brackets. Its just a bit of the side piece in front of the weld joint and will not affect anything.
IMG_2008.jpg~original
Its a tight fit, but is exactly what I needed to mount my plow. Funny thing is, it still hasn't snowed enough to use it this winter. No complaints.
IMG_2003.jpg~original
IMG_2006.jpg~original
IMG_2004.jpg~original
I believe it was $154 to my door. Check Amazon.com and search for Reese 65041. I'm at the shop, but if you can't find it, send me a PM and I'll check tonite.
erinobr2000
