frozen doors in "ice ville"
3bears
Senior Member
I live and work where it has snowed all but 4 days since thanksgiving. temps rarely above 30...that's a heat wave. usally the low teens at night and mid 20's in the day
the doors are often frozen stuck and some day I fear I will yank the door handle off the door
ive read where some people spray the door strips with wd40 to keep them from sticking but I wonder if the chemical comp could degrade the weather stripping.
wonder what others in "ice ville" do
I spray silicone lube on a rag and wipe the door gaskets. Makes a huge difference. If you live in saltville then slowly degrading rubber is your least worry.
You can also not close them fully. Just stop at the first click.
I do this when I get it washed in the winter.
Make sure the dome light doesn't stay on though.
You can also leave the windows open a 1/2" so they go down.
I have skinny fingers so I yank the top of the doorframe instead of the handle
Sent from my Z958 using Tapatalk
I have skinny fingers so I yank the top of the door-frame instead of the handle
^^ Same here.
- usually after a freezing rain ice storm, the door edges need pried open...without tugging on the door handle & breaking it
I also leave my driver window down, an 1/8th inch...so it doesn't freeze shut & put undo stress on electric motor.
Dang. I had my door freeze shut once in Tahoe and thought that was a big deal. Crazy stuff... I live in (not so) sunny California but it rarely drops below 30 degrees.
Wax has always been my solution when I lived in colder climates. Of course the remote start is also a great thing to have. Just don't forget to leave the heat on high.
seltzernator
