FS: 2000 4Runner 3RZ 2WD 5-Speed - Greenville, SC
TooManyTYTs
Post on Facebook: https://www.facebook.com/share/1EEkiENETe/
Base model. 1A5 paint. Two wheel drive, 5 speed manual transmission, 3RZ engine. 315,000 miles. I am the 2nd owner (purchased at 312k 3 years ago). Clean SC title. Message me for a Vin# if you want it.
Selling to thin the herd. I'm not driving it enough. This website will not let me post pics but I will gladly email or text them.
Greenville, SC near Wade Hampton High School.
The Good:
Sourced from Florida auction with a spotless rust-free frame
It’s 2 wheel drive and gets excellent gas mileage/ feels peppy off the line.
Excellent aftermarket stereo with blue tooth
Lights, dash bulbs, locks, windows, switches, A/C, heat, & rear hatch window - all are good to go.
Non sunroof model.Intact B+ grade original interior.
Replaced/ wrenched on within last 3,000 miles:
New clutch (oem, installed by All-Trans of Greenville - best transmission shop in Upstate SC)
Shocks and springs
Radiator (all aluminum)
Idle Air Control Valve unit
All air and coolant hoses
Oil pump and seal
Rack and Pinion (new oem $800 unit from Toyota of Greenville)
Control arms
Tie rod ends
Lower ball joints
Brake work (fluid flush and pads)
The Bad:
It’s 2wheel drive.
Weatherstripping along the doors is dry rotted.
2 spots of rust forming on body under front doors
Clear coat fade on hood and roof.
Bumper and door dings, nothing major.
Drivers seat undeside foam is worn out (exterior fabric is clean)
The Ugly:
Ownership may lead to thought patterns that will convince you to lower it and install a turbo kit
Ownership may lead to thought patterns that will convince you to lift it and install an electronic locking rear differential
Come have a closer look and decide for yourself. It’s beautiful for what it is and ready to be driven as-is or restored/ enhanced further.
Mods:
Roof rack, running boards, fender flares, and spoiler all have been deleted. Roof holes are patched.
Matching 1A5 Desert dune metallic side mirrors from a limited.
Limited 4runner (4th generation) 17” alloy wheels with Michelin LTXs. (slightly larger than factory spec tire size)
Extra parts:
hatch, original 15" wheels, lift gate struts.
2001ATL
