FS: 4 Gateway Buckshot Mudder Tires on Toyota Wheels, $600, Chesapeake, VA
midcoma
Member
Selling a set of 4 Gateway Buckshot Mudder tires mounted on factory split-3 aluminum wheels. I bought the tires to use on my 4Runner, but they'll be too small with upcoming suspension mods. I bought them used, but haven't used them myself. Tall and skinny, P78-16LT. Tires are bias ply, which is great for offroad durability but will most likely be loud and difficult to balance for road use.
-32.5" tall and just under 9" wide (extra 2" at end of ruler in picture).
-25/32 tread depth.
-Tires are mounted with XtraSeal Bead Sealer on inner and outer tire beads to prevent slipping and ensure sealing at low pressures.
-Each tire has 14oz of airsoft bbs inside for balancing.
-Tires have been cut and siped for increased traction and better tread clearing. I added the cuts and sipes after I bought and mounted them.
-New valve stems.
-$600 for the set. Local pickup only. Chesapeake, VA.
Cuts & sipes
Tried checking the date code but they aren’t legible. I’m not sure how old they are. I’ve had them for a few years, but I bought them used. They’ve been stored indoors the whole time I’ve had them.
