FS: 5th Gen: 2017 TRD Off Road Premium Wheels and Tires $600 - San Diego CA
2112 R
EDIT: I'm back in the states and these are still sitting in my garage so ....
Reduced price and now asking $500
2017 4 Runner TRD OffRoad OEM wheels, center caps and tires with no sensors.
3 Tires are currently not mounted. Less than 750 miles
1 Tire is mounted (story below) 0 miles on it
TPMS on all 4 tires removed
Tires are stock Bridgestone Dueler H/T 265/70/17
When I switched out the set one had a slow leak, which was due to a screw in the tire. Leveraging the warranty, I took it back to the dealership who just gave me a brand new tire and mounted it. Therefore, this is the mounted tire with 0 miles on it.
This is represented the 3 tires with 750 miles on them:
This is for the tire with 0 miles on it:
Now if I could only find 3 other people wanting to buy just ONE rim/tire I would be set!
GLWS
Fat chance, but I would be game to buy two and split the set, just to get the wheels.
If anyone is game, plz send me a message
They're still available and I'd split the set if all parties can meet at the same time.
Trying to avoid a situation where I split the set, another buyer backs out and I'm stuck with only 1 or 2 wheels/tires.
Just to be clear on the description as I've had a few questions;
1 wheel has a tire fully mounted, balanced and inflated on it. That's the one from the dealer that was replaced.
3 wheels all have tires on them, but they are all deflated as the tire air stems are missing. So the seal/bead is broken (as you can see in the second pic), but all they need are some tire air stems and then air them up and they should be good to go. They might need to be balanced as the tire has moved somewhat on the wheel as I moved them around. Maybe someone more technical minded in these things can correct my terminology.
In the end they're all pretty much just like new as they have barely any miles on them.
Laredotx
