FS: 5th Gen camping setup - $300 Seattle, WA
pstur11
For sale is a camping setup made for a 2021 4Runner - it should fit in any 5th gen 4runner. Everything is secured using factory tie down location and mounting points, and zero vehicle mods are needed to install this. It has worked really well for camping as the shelf is a great work surface while outside, it's great for hauling camp gear, and the bed being as low as possible maximises headroom and comfort while inside. When inside you're able to sit upright. There are zero squeaks or noises from this setup and it is extremely solid. Everything is built using imported baltic birch, either 18mm or doubled to 36mm. The rear shelf is also designed to be easily removed while the side supports stay installed, this allows large items to be easily transport (see picture of unfinished wood). What's included in this sale:
- Bed platform
- Mattress (4" thick)
- Rear shelf
- All hardware for installation
Local pickup to Seattle only. It is still installed in my vehicle, and it may be easiest for you to be there when it is uninstalled.
premiumusedautoparts
