FS: ARB SIMPSON III , Roof Top Tent (RTT) and Annex, SoCal
the4tion81
SOLD: ARB SIMPSON III , Roof Top Tent (RTT) and Annex, SoCal
Up for sale is my ARB Simpson III RTT in great condition with all original hardware; Annex (included) is still new, never been used and only taken out of the bag by the original owner to show me it's condition and how easily it set up. The only issue I can think of is a small wear spot on the outer flap covering the hinge (pictured below). I would prefer local pickup here in the Los Angeles, CA area. Sold as is.
The tent is currently stored inside.
Find pictures below of it on my 4runner (in Joshua Tree 2 weeks ago), interior pictures, and pictures of the annex attached when I originally purchased the tent.
PRICE: SOLD
FACTORY DESCRIPTION:
About the Product:
The ARB Simpson III Rooftop Tent will provide the ultimate in ease and convenience when travelling. Unfolding in minutes, a rooftop tent provides sleeping quarters off the ground, protected from the elements. Spacious and comfortable, all bedding can remain inside the tent during the journey, freeing up vital storage space in the vehicle, and allowing the tent to be quickly and easily packed away.
Features:
Series III Tent Incorporates an Updated Design and New Materials for Better Strength, Rigidity and Water Resistance
Manufactured from High Quality, Poly/Cotton Fabric
Incorporates Oxford Polyester Flysheet, with Excellent Water Shedding Ability
Sturdy Aluminum Retractable Ladder
High Density Bonded Chip Foam Mattress with Removable Cover for Increased Comfort and Durability
Incorporates Pull Out Veranda and Optional Zip-On Annex
Insect Screened Windows and Door
SUV Stabilised Laminated PVC Cover
Bungee Cord System to Assist When Closing
Easily Mounted to ARB's Purpose Designed Roof Rack
Can be Configured to Unfold off Either the Side (Shown) or Off the Rear of the Vehicle
Size:
55" (1400mm) wide x 94.50" (2400mm) long x 51" (1300mm) high
All Aluminium Components Feature an Anodized Finish for Improved Corrosion Resistance and Apperance
Comes Complete with Mounting Hardware, Wrenches, Ladder, Travel Cover and Comprehensive Instructions
ARB Awnings can Also be Paired with the Rooftop Tent.
how do these mount on the roof rack? very interested but i have a ROLA roof rack on right now with LED lights on top, I probably have to take that off eh
[MENTION=114741]RunnerLimited[/MENTION] The factory mounting hardware slides into aluminum extrusions and has 2.5in (I believe) stainless steel bolts that will hang either side of your mounting rail, connected then by a 3" zinc plated steel bracket. The aluminum extrusions and RTT can be positioned to open/attach either on crossbars or outer rails. As far a a rola rack, the concern would be if you have that rack mounted to the factory crossbars or to the factory rails. I wouldn't recommend mounting to factory crossbars for longevity of the setup. However I would think a rola rack would support the weight (that you would need to check). I had this RTT attached to a drabbits rack. Let me know if you have any other questions. Thanks.
ghengiskhan
