FS: Eastern WA - DIY DOT Approved PowerTank & Overland Equipped Fuse Block Mnt 10-19
jayhat
Overland AUXILIARY FUSE BLOCK MOUNT FOR 5TH Gen 4RUNNERS (2010 - 2019)
$35
Overland Equipped AUXILIARY FUSE BLOCK BRACKET MOUNT FOR 5TH GENERATION TOYOTA 4RUNNERS (2010 - 2019, 2020+ WITH MODIFICATION)
Pics: Update your browser to use Google Drive, Docs, Sheets, Sites, Slides, and Forms - Google Drive Help
DIY “PowerTank” co2 tank setup with DOT co2 tank, PT mount and handle, valve w/ QD
$320
Pretty much everything is power tank brand aside from the Co2 tank - which is a DOT approved aluminum tank. With valve and QD air chuck. Powetank brand tank mount and cover. With handle.
Tank stamped: DOT-3AL-1800 CC445059 #10 co2 t13.6lb 3alm124
This was filled up and not used since the last fill. I just don’t off-road enough to need this. I just take my little compressor most of the time.
