FS: Lots of 3rd gen parts - Oregon
Sweet bud. Got a price? And do they include the brackets to connect them?
Sent from my SM-N910V using Tapatalk
You'll definitely need a new set of clips and weatherstipping, and some paint so they'll be cheap, probably like 60$ plus shipping, I do have the metal brackets that go on the rear doors somewhere, ill have to look for em though
Got some more stuff today, some more tan leather armrests, more 99+ woodgrain bits and pieces, a set of Black Pearl colored 99+ Limited badges, 99+ ashtray, and I'm sure there's more, don't hesitate to ask, I've got a ton of stuff, big and small.
This may sound a bit odd but have you ever come across any broken wide fender flares? Only the bottom has to be ok.
I am looking for the bottom 3inches or so from all 4 but I can't bring myself to cut good ones and I haven't been able to find any in my ao. I am going to use them to fill a BL gap between the bumper and my flares....if i can ever get a set. Don't care what color.
I actually come aross beat up ones all the time, it's usually along the upper portion of them, if you've got a decent budget and timespan I can definitely find em and sneak em out over the next month or so. I'd estimate you'd probably be in it around 40-50$ by the time I got a set of 4 though.
Perfect...your mission, should you chose to accept it.....starts now...
I'll wait to hear from you. PM me for better contact info than just here.
And thank you!
I am looking to get the pieces just off the bumpers....the last 3in at least. They are flat on the bottom ....that's how I hope to connect them to the originals...to extend them as it were. Should match the contour well enough.
Can't stand the gap. These are the last pieces needed as I have the front, back and inside the wheel wells taken care of.
And thank you!
Ok, so you need the front bumper caps and mud flap pieces off the rear bumper?
Nope...end pieces of the flair itself. Cut off no less than 3in long. The section closest to the bumpers, the next piece up from the caps and flaps.
As long as they still have the flat inside end intact ......
You got it, I'll start gathering em.
I don't have a set on hand but I can definitely get them, are you looking for the brackets to hook the swaybar to the frame or the endlinks?
Thanks! Just need the brackets (and nuts and bolts) to mount sway bar to the frame, I'll buy brand new links so no worry on those. Somehow I ended up with only one bracket and want to put my front sway bar back on. Thanks and let me know if you think you can help!
Thanks! Just need the brackets to mount sway bar to the frame, I'll buy brand new links so no worry on those. Somehow I ended up with only one bracket and want to put my front sway bar back on. Thanks and let me know if you think you can help!
I'll have a set for you on wednesday man.
matisgugle
