FS: New Eibach 14", 3"ID, 600lb Springs.
Greydog
Member
Selling a set of New Eibach springs which were removed from my Fox CO's prior to install.
14" length
3" Inside Diameter
600 lb rate
These Springs would be best for a coilover from Fox, King or Radflo. I think they are too short for a stock shock, but may work on a 5100.
Asking $150, buyer pays shipping from 06413.
Thanks, Mark
Depends on the shock, probably too short for a stock shock. May work on a 5100 adjusted up.
Yeah I have 5100 now with the FJ spring compressed and want to lift the front without having to preload the spring... I have a v8 with and icon 2 in spring in the back
After some research, I dont think these will work. The coilover springs are flat cut on both ends, and are 600lbs which us not much higher than your FJ springs.
Just as helpful tips, since I just sold a similar pair of coilover coils myself...
These wont work with the 3 perch Bistein 5100s but will work with the Bilstein 5100s designed for coilovers.
In addition, these coils will work with any 2.5" coilover body shock. Fox, King, Icon, Radflo, Sway-A-Way, Dirt Logic, etc..
[MENTION=58830]JWaldz[/MENTION],
If I purchase toytec boss coilover springs could I put them on a 2.0" coilover body shock, like a radflo, icon, etc like you stated above about the springs above?
As long as the Toytec Boss Springs are 2.5 ID then yes they will work on a 2.0 body coilover shock. I believe they are as the only 2.5 body shock they sell are for the 5th Gens and 3rd Gen Tacomas.
2.5 ID Coilover Coil --> 2.0 Body Shock
3.0 ID Coilover Coil --> 2.5 Body Shock
etc etc...
