Fuel pressure tester recommendations?
Anyone know of a Fuel pressure tester kit that has the right fitting to tap into to fuel line at the connection just before the fuel damper on V8?
I ordered this p.o.s. kit off amazon:
Amazon.com: BETOOLL Fuel Pressure Test Kit 0-100PSI with 9.49,7.89,6.30 Fuel Line Fittings: Automotive
It just sprayed gas everywhere because the cheap plastic clip that's supposed to hold the fitting in place won't hold.
I used that same kit # on my '07 V6 4Runner, and the quick-connect was a tight fit onto the chassis line...but with a light film of clean oil on the line surface it clicked into place.
I must have gotten a defective one then. The fit wasn't the problem, it was the plastic clip that was supposed to hold it on. It clicked into place alright but as soon as I started the engine that fitting blew right off spraying gas all over.
I put that larger clip on that goes over the normal fitting and it held it in place. I dunno, maybe I was supposed to do that to begin with?
MaximussK
