grinding noise coming from rear end
sloopy
i have a 98 sr5 4wd and the rear end is making a grinding noise i know it is not the brakes because i jacked the rear up and the wheel spun freely. i changed the fluid after i noticed the noise and it almost seems worse. i dont really have any experience with rear ends do you guys have any opinions or have you ever had this problem?
how bad were the metal shavings on the magnetic drain plug? when was the last time you lubed the driveshaft?
i lubed the drive shaft yesterday, and the metal shavings didnt look terrible it looked almost like black grease on the drain plug.
i bought this tr4 one week ago from a lady and she had someone pull the parking brake and it stuck because noboby ever used it. so when i bought it i was thinking that it was the back brakes hanging up allittle bit but its not the brakes. :confused:
well about an hour ago i jacked the back of the truck up again and it did seem like it was grinding a little when i spun the wheels i pulled the drums off and dropped them off at napa to have them turned. i took the runner to a shop they drove it and said it was not the brakes but maybe it is. i will know about it shortly.
nope not the brakes. when i drove it down the road i would excellerate and then let off and coast and i would hear the grinding noise.:( :confused:
so how can you tell wether its a bearing or the gears? i have read a good article on how to change the rear end seals and it sounds easy enough.
sloopy said:
yeah i greased all the zerks i didnt lube the zirk fittings but i know that the grease went in.?
you should see grease seep out of other joints. BTW, if it is your u joints that are making the noise, greasing them won't help too much. you'll need to replace them. But they're cheap...
grinding sounds. like you mentioned. so you know it's not the brakes, probably not the wheelbearings. replacing the u joints wouldn't be a high risk repair since they are so cheap.(about 10 bucks per u joint)
BillM777
