Grinding Sound (right front kick panel) Could it be ABS 89540-35122
TRD 4RNR
Member
I'm hearing a grinding (almost like a bad wheel bearing) sound coming from the right front kick panel area.
Could it be ABS 89540-35122 ?
Or maybe it's the transmission relay 89531-35030 ?
I've pulled the panel - pulled into the cab the sunroof drain line and moved other misc wiring and the sound continues. Any ideas?
I should also add that the noise gets much louder when I hit 68 mph and it is at its loudest at about 75 mph
PRWhite
